Spare wheel for Series 3 1.6i 1990
I couldn't agree more just because you can do something doesn't mean you should. Laptops are a prime example, give me than two sodding ports!! I don't live in that dreamland where everything works flawlessly over WiFi, I'm barely on dial up speeds here! Also what is with that dreadful piano black trim? Scratches the instant you look at it, and in my opinion I think it will date really badly. All new cars seem to have it, especally the EV's. Is it cheap to produce? Still trying to learn how to use the reverse camera😁... and failing! -
Just purchased 320d Touring
Hi, Yes. The BMW decoder worked well. I do indeed have a G21. I'm off to Dorset soon, so really looking forward to giving it a good run. Full spec below: S90A 90 AH AGM battery L812A Great Britain/Ireland version P337A M Sports package S1AGA Larger-capacity fuel tank S1CBA CO2-scope S1PDA 18'' M light-alloy wheels double spoke 790 M bicolor with tires of different makes and types and emergency running properties S230A EU-specific additional contents S248A Steering-wheel heating S258A Tires with emergency running properties S2PAA Locking wheel bolts S2TBA Steptronic sport transmission S2VBA Tire Pressure Monitor S2VLA Variable sport steering S302A Alarm system S322A Comfort Access S3KAA Acoustic glass S3MCA M roof rack high-gloss Shadowline S418A Luggage-compartment package S428A Warning triangle S430A Interior and exterior mirror package S431A Interior rear-view mirror with automatic anti-dazzle function S481A Sports seats for driver and front passenger S493A Storage compartment package S494A Seat heating for driver and front passenger S4KLA Interior trims Aluminum 'Mesh Effect' S4URA Ambient light S534A Automatic climate control S544A Cruise control with braking function S5A1A LED fog lights S5A4A LED headlight with extended equipment specification S5AQA Active Guard Plus S5DAA Front passenger's airbag deactivation S5DCA Rear-seat headrests, folding S5DNA Parking assistant Plus S610A BMW Head-Up Display S654A DAB tuner S688A Harman Kardon Surround Sound system S6AEA TeleServices S6AFA Statutory emergency request S6AKA/S6C4A ConnectedDrive services S6DRA BMW Drive Recorder S6NWA Telephony with wireless charging S6U3A BMW Live dashboard professional S6U8A BMW gesture control S6WDA Personal hotspot S704A M Sports suspension S710A M leather steering wheel S715A M Aerodynamics package S719A Edition Sport S760A M high-gloss Shadowline S775A M Headliner anthracite S850A Additional tank filling, export S853A Language version English S880A English / on-board literature S8KBA Oil service interval - 24 months / 25,000 km S8R9A Refrigerant S8S2A Coding of alarm signal S8S3A Automatic lock when driving away S8SMA VIN, visible from outside S8TFA Active pedestrian protection S8TGA ANTI-THEFT SYSTEM S999A Order control HEA- 1
Morning Paul A wheel bearing normally protests under load when driving (groaning rumbling worse when cornering) CV Joint clicking sound, have you checked the condition of the CV Boots ? As an X5 pilot what condition are the tyres ? Have any or all been changed recently ? If the tyres (even 1) are out of spec Transfer case damage or diff damage can be caused (gives similar symptoms to those you seem to have Dave -
I noticed that when i put my x5 in full lock, lets say towards the left and i drive it makes a clunking judder sound. When i straighten up that sound is no longer there. Can anyone tell me how can i check to see if it is the front drive bearing or the CV joint bearing? Thank you Car spec. X5 E53, 54 plate
