Parking light malfunction
So Im new to BMWs. I have 16 x3 xdrivei28. The other day it through a parking lamp malfunction. I changed the bulb with the exact same bulbs. Still have to code. Bulbs were working. Then I swapped em with LED ones that were made for it. Still same thing. How do I reset the thing or is there something else with it??? I'm so very confused.
Morning Will
As you have replaced the bulb without success have you checked the fuses ? You should find a Fuse diagram tucked away somewhere but try checking fuse numbers 10, 15, 20. If the fuses are good then you need the help of either an Auto Electrician or someone with a BMW capable diagnostic scanner
