The mobile charging tray on my 330i has stopped working. Any ideas what the problem might be?
Morning Paul
First point of call check the fuse diagram and fuses if that doesn't fix it then a Diagnostic Scan is needed by a Dealer £££ an Independent a Specialist or someone with a BMW capable scan tool
A quick look at ISTA WIS shows fuses 120 and 128 are phone related
Hope this helps
Hi Dave, thank you for your message and tips. Long story short the problem was actually with my phone. I went to my local garage and they placed their own mobile on the charging pad and it worked, unlike my phone. I tried the equivalent of control alt delete, switched the phone off and on and lo and behold it started working!! Cost: no charge.
Thank you for trying to help.
Regards Paul
Regards Paul
Hi Paul,
Out of interest does you wireless charge tray actually charge your phone?  Or does it just turn it into a small heater that get hotter than the sun, causing the phone to shut down due to overheat and put a very small amout of charge in it as mine does?
