I'm hoping someone can give me a few pointers. I have a 2012 E84 25D and recently I've been getting the following intermittent codes:
4862 Air System, Air to EGR Mass Flow, Plausibility
4873 Exhaust-Gas Recirculation Cooling, Plausibility
4530 Charing Pressure Control, Control Deviation
The car drove fine, no loss of power. I removed the EGR and Cooler to check them and there was very little carbon and both clear. Both were replaced around 10k miles ago under the BMW recall.
The car has now gone into limp mode and is making a weird noise when reved. It's quite at idle but makes a lowish pitched drone or whining noise when the engine is reved. It's not a high pitched whine that I would associate with the bearings in the turbo. I had a fondle of the turbo spindle when I had the intake pipe removed. It spins freely and I cant feel any play in the bearings. The car has only done 55,000 miles and has a full service history with oil changes every 4,000 miles so I'm hoping the turbo hasn't failed already.
I thought I'd try and check out the control system first. I looked at the parts diagram for the turbo vacuum control and started trying to check things. Connected a vacuum gauge on the supply side and the vacuum appears steady so I don't think there is a leak on the supply side or vacuum tank.
I removed the vacuum line from the part labelled Vacuum box (15) on the parts diagram and the droning/whining noise stops. I connected a syringe to the Vacuum box and as i draw a vacuum the noise returns. Turned the engine off and used the syringe to draw a vacuum while feeling the actuator arm under the vacuum box and the arms moves/returns freely when a vacuum is applied/released.
I can't work out what this vacuum box operates. The actuator arm passes down through the exhaust manifold and is connected to the turbo.
Can anyone tell me what this does or suggest any next steps to try and diagnose the problem?
Thanks
Jim
Morning JIm
If memory serves your car has twin turbo's a small one for low/mid range and the bigger one below for mid/top end boost. The vacuum drive shifts boost to the larger turbo, so when you felt for any wobble which turbo were you feeling? and which side remember the exhaust side really does take a battering. From your description the Vacuum drive is working but the flap it operates into the large turbo or the turbo it's self needs some investigating
Those are my thoughts
Many thanks for your input Dave. My car does have twin turbos. I checked for play on the cold side of the larger/bottom turbo by removing the air intake but I take your point about the hot side taking more of a hammering. I can feel the actuator move at the vacuum box but I can't access or see the point where it connects to the turbo. I don't know if the flap moves freely - maybe the hot side is full of carbon as I tend to do short trips. Time to dig deeper so I've just dropped it off with a local turbo specialists who say they can run diagnostic tests and do a route cause analysis.
The car has only done 55,000 miles, full service history with oil/filter changes every 4000 to 5000 miles so I'm hoping the turbo hasn't failed already 😟
Thanks
Jim
Morning Jim
A Seat owned by a neighbours wife from new but only used for school run duties was completely clogged at lower miles than yours. Predictably the Dealer said new Turbo new EGR and a swathe of other parts £££, a local Diesel specialist stripped, cleaned and rebuilt everything and gave her the advice to give the car a good run at motorway speeds once a month. Years ago my son had issues with his Toyota pickup the dealer mechanic told him an "Italian Tune Up" (engine up to temp and keep revs over 2.5k for half an hour) needs doing every few weeks. As a Tree Surgeon he tended to be trundling around off road at slow speeds and low revs.
With luck it's just the actuator mechanism
      No boost and strange noise
      Bmw E30 Touring
    5. 8
      2007 525i
    • IanW5177 earned a badge
    • Ian old e36 earned a badge
    • Pezza Singh earned a badge
    • Joe Quad earned a badge
    • slick209 earned a badge
      Reacting Well
