big ally
bigally
My M2 tyres are extremely noisy, so I went to my local tyre centre to have them checked. I was told there are numerous small bumps on the inside and outside of all my tyres which will be causing the bearing type noise. I have still got the original Continentals on and have done12k miles. The noise started probably around 6k miles. Has anyone else experienced the same problem and what was the outcome.
1 hour ago, bigally said:
I don't know. The fact it is multiple bumps on all four tyres makes me doubt it. However you may be right.
Have you contacted Continental to see if it could just be a bad batch of tyres. They may help with some goodwill for the replacements. Tyre companies are usually pretty good.
Upt'North.
      Coolant leak
      Coolant leak
      Coolant leak
    4. 5
      2e47 & 2e41
    • Kev Miller earned a badge
    • Jeags earned a badge
    • olly530i earned a badge
    • StuMc earned a badge
