Hi all I have a 54 plate 2.0L diesel x3, a few weeks ago I had warning lights on the dash, plugged in a reader and got rear right sensor fault, so I changed the sensor and cleaned the sensor ring, fault cleared after a few times of resetting, so gave driven the car for a few days all good, now I have the same fault lights on the dash so stop the car turn off restart fault gone drive some more and at different times the fault comes back, now reads rear right sensor air gap, can any of you recommend a fix
Thanks
John
Morning John
From your description we are talking about the the ABS sensor and reluctor ring? When you say you cleaned the ring was it badly corroded? If to much surface came away while cleaning it could give an un-even air gap? Also is the new sensor seated properly and torqued to 8 n/m? I have also read that the ABS unit can throw these faults
Sorry no solution but my thoughts
Check www.newtis.info there may be something for your model there as it is the same technical information used by BMW Dealers
Thanks dave, I have spoken to a couple of garages and the recommended changing the drive shaft and sensor
      Do I stick or twist?
      Scratching on rubber trim
      X1 gearbox service
    5. 3
      X1 gearbox service
    • Johnbeemer earned a badge
    • davecullen6 earned a badge
    • Vinceh. earned a badge
    • Moo1996 earned a badge
    • Steve Martin earned a badge
