320d efficient dynamics Bluetooth connection problem
Coolant leak
Morning Kev Welcome to the Forum I am aware that the plastic return pipe (Header Tank to Rad) on the E53 became very brittle and was easily damaged. I replaced mine with 10mm Copper Tube after a long wait for replacement. But I was not aware, or haven't heard of X3 issues here in the UK I guess that you will need more from US based owners Dave -
Coolant leak
Hi, quick query if anyone has experienced this issue. Purchased an X3 S drive 20I brand new, delivered on the 18/3/2020. All services conducted when required by dealer. Last service (major) was done on the 9/4/24. Approx 1 week later coolant leak was discovered. Vehicle towed to dealer, cause was cracked coolant pipe . Informed part would take 2 week delivery time ( ex Germany) at cost of $800. Vehicle has just under 30,000 on clock. Any input greatly appreciated. Thanks -
5
Good to know Dave, Thanks! If I can't use them on the fob I'll put em on something. Here Kitty Kitty:) -
2e47 & 2e41
Hi Joe If memory serves 2e41 is bad communication between the EWS and DDE the other 2e47 is Thermostat or Sensor related. Looks like that sorts your weekend Dave
