Windscreen washer fault
Carlbmm
When I try and spray the windscreen the motor makes the right noises but no water comes out. The jets don't seem to be blocked.  Any suggestions as to how to get to the motor to see if there is a blockage at that end.   Carlbmm
I have this issue, lucky for us there are plenty of threads about cleaning out the filter at the bottom of the washer bottle. My rear washers work fine but the fronts do not. I have read it should only take an hour to sort.
Hope this helps
      Wireless charging?
      E92 Preventative measures
    3. 5
      650i crank no start
      Wireless charging?
    • Astonred earned a badge
    • Daz9048 earned a badge
    • Sbannas earned a badge
