E92 335D 2008 Dpf Warning Help Needed
hi, i bought a 2008 335d about 2 month ago. after 1 month of driving to and from work i get the particulate filter message coming on the idrive screen. no loss of power
i got my mate to code read and it brings these codes up.
present 43D1 DDE Throttle valve actuator activation
present 4530 DDE Charge air pressure control diviation
present 4D00 DDE exhaust back pressure sensor
not present 4667 particulate filter system
present 480A particulate filter system
not present 49E7 throttle acuator
present 481A particulate filter system
after a full code clear, i take it for a 8-10 mile drive and the particlate filter warning doesnt come back but flags these errors codes.
not present 4530 DDE Charge air pressure control diviation
we forced a regen, and drove 30-40 mile at 60mph. checked on scanner and it said it had regen.
1 month later, particulate filter warning on again.
exhaust back pressure is reading 35mbars at idle, 60-70 when reving in neutral. 100mbars cruising at 60mph, and about 800mbars when thrashing it
can anyone shed some light on this?
thanks
