What Does This Warning Light Mean?
Cammie1912
Please help, have this warning light come on at start up of mini clubman D 2010. Can anyone tell me what it is, doesn't make any difference if auto stop/start is switched on or off (not that it works anyway). Not anywhere in manual or internet
post-11030-0-45599600-1427640476_thumb.j
It means Automatic Start/Stop System failure.
Malfunction
The automatic start/stop function no
longer switches the engine off automatically.
The indicator light lights up. You
can continue your journey. Have the system
checked.<
Is a bit weird its taken that long to realise. Hopefully its a simple fix. How good is the battery? It could be its sensing that its not optimal and as you probably know, if everything isn't running perfectly the system wont work.
The battery hasn't been changed since the car was new and it has had a period of sitting around and not being driven much so that could be the answer, thank you again. Will get it checked. Would be the simplest solution I am sure.
      Resonator assembly clip
      04 525d
      2e47 & 2e41
      Coolant leak
    5. 2
      Coolant leak
    • Droffilc earned a badge
    • Robbawdie earned a badge
    • Kev Miller earned a badge
    • Jeags earned a badge
