Day Time Running Lights
Hi tower
had the same problem ,ended up by letting a small independent BMW garage install
even they said it was a problem to do cost about £60 official garage wanted £150
This forum is NVG suggest you try X Bimmers they have a lot about X1 but mainly Americans
adding bits and pieces etc
Thanks I dont think.
It looks like some have disconnected their fogs to power the DLR's which is a bit pointless. I take it you dont have the Day Light running Angel Eyes because you could have piggy backed these. Alternatively try getting the wireing in under the dash. As the drain is so low you should find something under the dash that is permanent live to link to.
It ok thanks sorted the problem, took 12v supply from just start post under bonnet and used a smart relay (as used in Caravans for the fridge etc), this relay turns the lights on when the battery is being charged approx 13V cost £10 ;)
  • 1 year later...
    2. 14
    3. 14
    • MikeDT earned a badge
    • Sdspeed went up a rank
    • Sdspeed earned a badge
    • Kiernan earned a badge
    • phil angel earned a badge
