1 Series Battery Problems
- contact failure
(and 2 more)
Tapping
Engine cut-out on idle.
Morning Damien Welcome to the Forum An internet search may give more information particularly the US sites Your BMW Dealer may not have seen it but that doesn't mean its not there. I have also read that the new cars when plugged into the Dealers system now have to be linked to BMW Gmbh They really don't make it easy do they, Technology is great until it stops 😅 Hope they can sort it with a software upgrade or something simple so you can enjoy your car again (sneaking around in silent mode🤣) Dave
