Rock Solid Brake Pedal
lingo
A quick google search threw up a few threads about possible vacuum (air) leaks causing stiff brake pedal and checking all of the lines may show up a fault. Might be worth a look. This can also result in a slight missfire of rough idle. Apparently.
The servo and master cylinder that were sent were wrong so no luck as yet. I too have read those threads hence the purchase of the relevant parts. I have no ruff idle though and the non return value on the vacuum hose is working. So I'm almost certain it's servo related
      E66 76Li - help needed with errors
    2. 4
      Noob
    3. 4
      Noob
      key fob programming
    • Luckysod earned a badge
    • Bluebeard earned a badge
    • X5vince earned a badge
    • dave79 earned a badge
