Excessive Oil Consumption
choral
not a "Known" problem, no.
there are a number of reason why it could be using an abnormal amount of oil. Before I start hitting you with things to check and things to start yanking at, how mechanically minded are you? 10 being you'll happily do a head gasket job and 1 being you could confuse a spark-plug with a toothbrush. If you're pretty handy, we can do the diagnostics without the need of a grease monkey
Daz
Guest Mr.Beemer
they tend to use a bit of engine oil which is normal but not a problem. when you say a lot of oil how many litres and miles is it getting through ?
does the car smoke or have you checked for leaks -
engine oil grade > use recommended.
Guest Mr.Beemer
that is excessive engine oil use. the car clearly has a problem. if there is no leaks then its burning through them 2 litres.
a good guess will be valve seals. would you know how many miles its driven ?
Does it puff smoke at startup and then go away after a short while? If yes then valve stem seals...
If you smell burnt oil (much different from fuel) constantly, then maybe the rings have worm somewhat.
A poorly engine breathing system will draw oil into the fuel system too, so maybe try flushing the pipework first ;)
      Locked out of a 1990 525i
      Android auto
      Exhaust tips
    4. 0
      Insane insurance quotation !
    5. 3
      BWM 216D F46 Issue.
    • Wolfgangk earned a badge
    • steve k earned a badge
    • Lerxst earned a badge
    • ARoosterinaRoadster earned a badge
    • CJP earned a badge
