Heating Gone
maverp1
The heater has finally stopped in the car never been the best since I had the car fisrtly only heat from drivers side then yesterday fans stopped working so checked fuse all good after a bit of research Im thinking it's the heater control valve just a couple of questions do I have to bleed and refill the coolant after replacing and do I need to replace both the control valve and the auxillary pump underneath it ie are they connected any help much appreciated
Cheers Paul
      Coolant leak
      Coolant leak
      Coolant leak
    4. 5
      2e47 & 2e41
    • Kev Miller earned a badge
    • Jeags earned a badge
    • olly530i earned a badge
    • StuMc earned a badge
