Ignition Barrel Worn
Hi I think I have the same proplem as some of my instruments work when they feel like it, I went onto utupe and looked up e38 750i faults and the most common for this was the ignition switch, have a look on utupe and it show's you how to fit it, it's quite simple
I bought one on eBay for £30 .
Regards Jon
At Laird Investigations
JonLaird.pi@ gmail.com
You can change the barrel easy enough without going to dealers, just make sure you don't damage the ring around the barrel as that's apart of the immobiliser
Can you turn the key in the barrel or not
      Resonator assembly clip
      04 525d
      2e47 & 2e41
      Coolant leak
    5. 2
      Coolant leak
    • Droffilc earned a badge
    • Robbawdie earned a badge
    • Kev Miller earned a badge
    • Jeags earned a badge
