Knocking Stroke Rubbing Noise
maverp1
I have quite a load knocking stroke rubbing noise coming from what seems to be under the gear lever it only happens after the car has been parked for a while and after about 100 to 200 meters disappears completely and the car drives great. Never noticed on test drive because as I say only happens after being parked up for a while .Any help much appreciated
Cheers Paul
I had the same car and the EXACT same problem (1997 728i E38)
Reason: Exhaust bracket failure. Your vehicle has two back boxes. They are supported by a hanger which is welded to the box. This weld broke on the O/S box causing the box to slightly sag. This (although NOT obvious) was catching on transmission when cold due to the contraction of metal relative to it's temperature.
Diagnostics: With the car running (From cold), apply small amounts of downwards pressure to the back boxes. Listen for a change in noise.
Solution: Replace back box or simply weld the bracket back on dependent upon levels of corrosion. Assure ALL brackets (Including middle one) are tight as even the slightest drop in the exhaust will cause this knocking/rubbing noise on the E38
I'm pretty sure you will have the same issue that I had. Your symptoms are too similar for it to be anything else. Hope this helps
Daz
(Possible alternatives: Prop-shaft bearing - Transmission coupling (doughnut) - Transmission mounts - Torque converter - Differential mounts - Transmission failure - Engine mounts)
Thanks to you all for all youre help DazH looks like you are correct my friend after getting you're message popped out with a tourch to check drivers side bracket on rear box has indeed snapped of will sort it some time this week and post to let you know results
Cheers Paul
Cheers Paul
You could have checked 2 days ago when I first told you! ;)
V8 sorry bud never saw you reply on here but thanks anyway just to let people know for future ref had the bracket welded back up to the back box and the problem has gone so as I said many thanks for all your help
Cheers Paul
Cheers Paul
Nah I was just taking the mick (755munich...)! :P
R.E. having them welded-BMW exhausts are made from a corrosion resistant material so while it's possible to weld them with standard steel MIG wire they may not last long as it's difficult to get good fusion between the 2. Mine just broke again after about 12 months. :mellow:
Lol thought it may be you on 755Munich yes mate as you said the lad who welded it for me did mention this but I will be looking into changing the back boxes so as long as it hold out till then happy days
Hi Paul. I'm 99.99% sure you've got a failing propshaft universal joint. It's seizing up whilst park then freeing as the propshaft turns. If you're mechanically capapable and have the tools, an houir of your' time and about 50 quid for the part should sort it.Hope this helps. Dave
Wrong diagnoses although a good try. Problem solved already
Daz
      Engine cut-out on idle.
      Amplifier replacement.
    5. 3
    • Sbannas earned a badge
    • Allan Wilson earned a badge
    • Danny428F33 earned a badge
      Reacting Well
