E39 Starting Problem
boatman
Hi there,I,m having a starting problem with my beloved E39 525d tourer switch ignition on and if I can,t hear fuel pump under passenger floor it won,t start I,ve replaced this pump its improved things a little seems worse when its cold but worse still if its wet I,m thinking theres a connection somewhere needs cleaning and sealing from wet not sure where to look.
Doesn't to me either but it could be the wiring to/from it.
^_^ so appose to checking the relay (Swap test it) run a Multimeter into the housing pins. Gotchya :P
thanks for all your replies yes its due for a service,I,ve never changed glowplugs but its definetly linked to wether the inline pump works if it starts or not am I right that the relay is near the battery if it was the glow plugs wouldnt it run lumpy when it started it runs fine when it starts and it never misses a beat while its running,It is without doubt one of the best cars I,ve ever had so it would be nice to solve this little niggle.Someone else said is it low on fuel.it was worse like this till I changed the fuel pump so I know what you mean.
      Failed turbo
    2. 27
      325i push button start switch
    5. 5
      Transfer Case
    • bill gall earned a badge
    • SGP earned a badge
    • Kandry earned a badge
