E36 Common Problems
G4VHD
Hi Guys................I went to start my car this morning, no joy!! Was fine lastnite when parked up on drive. Battery is fine got fuel etc, it was a very cold frosty morning. Anyone got any ideas? Thank you. Chris
  • 8 months later...
  • 3 years later...
  • 10 months later...
Hi Arnold
Any car not just an E36 can have problems after being left for a year. There can be, sludge blocking the pick up failed fuel pumps failed tank senders and fuel filter blockages.and Filler cap/breather
Those are the obvious ones that come to mind around the tank, you could also have sensor issues in the engine bay and injector issues
That's the negative stuff out of the way fingers crossed it is something simple like a blocked breather
  • 4 months later...
Hey guys !
I’ve been having issues finding a rear axle for my convertible 1998 323i. I’ve ordered one from every single possible website but everything I try to install its to long. Could there be an underlying problem with the rest of my suspension?
Morning Christhela
Not certain what you are trying to source? Are you trying to buy a complete assembly? Drive shafts?
The rear axle is made up from a Rear Axle carrier which holds the Diff. Drive shafts and suspension components determine the overall width of the assembly.
If you are not aware take a look at www.realoem.com put the last 7 digits of your Vin into the search box it will bring up your model the look at the relevant section. You will see a number of small exploded drawings that will help understand the assembly there are also Part Numbers so when buying used or new you will know your getting the correct parts.
Hope this helps
      Centre console iPhone charger
    • Penguin82 earned a badge
    • Stuiggy earned a badge
    • Massivemark earned a badge
    • Ste B earned a badge
