POst AA Relay Analysis
OK, had a motorway run and then stopped at filling station en route. Filled up but then the car just would not even turn over. Complete zip.
Managed to run the battery down trying and had to call AA.
The AA attended and tried and failed to get me going and had to be relayed.
One point of note was when the car did turn over there was absolutely no spark at all, almost as if no fuel was being pumped or the immobiliser was on. Got the fault codes and will share below:
System : Engine management 1 - 03K / Engine management Motronic ME 9.2 (8)
2A19 - Fuel evaporation regeneration valve.
2F44 - Immobilizer.
CDA1 - CAN message: Steering wheel angle sensor.
2DEC - Battery management.
Tried immobilize reset twice, checked fuel pump relay and powers and grounds,
Have put a new battery in but still engine turns over but no fire at all? Need to ask the right questions here.
Quirey immobiliser malfunction or fuel pump US. Any other thoughts appreciated?
Morning Paul
Some of your Codes will be due to dead or dying battery so first step after fitting and registering a new battery I would clear the fault codes, check the engine earth straps. Then try a start and see what codes if any return, it could be a worn key/ignition switch or a problem with the EWS. You will need a BMW capable Diagnostic scanner to be sure
Good Luck
