Keep real BMW owners helping real BMW owners, while we work towards motoring savings.
front brake reaction arm bushes
Hello again
Cutting to the chase, my wife having tried to tax the car discovers the MOT expired almost a month ago..... The good news is that we do have the car booked in for a test tomorrow morning but.....there was an advisory (which I don't recall being made aware of) on the last test
front brake reaction arm bushes worn
I've not had a chance to check these (when I find out what they actually are) and whether after having covered about 6000 miles since the last test whether these could mean a failure
Anyone have any experience in this area please?
Morning Gary
First when the car has been driven a sign that the Brake reaction bushes are on their last legs is vibration when slowing down (like an out of balance wheel) Particularly when slowing from Motorway speeds. As annual mileage is low you may get another advisory. Not an uncommon issue I have seen them failing from 70k onwards. Normally quicker to change the complete arm do both sides parts should be around £100 with the car on a ramp around an hour per side so if an Independent Garage is doing the job I would guess somewhere around £300
The arm is Number 5 below
Good Luck with the MOT
Hello Dave
Thanks again for a speedy response
The first MOT booked via some kind of aggregator site was a blow out - supposed to be at 1000 but when I arrived they said 1530... I found another nearer garage (main dealer for Peugot and MG in Colchester) dropped the car off at 1100 and just collected with a clean pass with a side repeater at about thirty seven quid and a rear bulk for about fourteen, the critical part is that there were no other advisories but they did put on a new set of LDH to RHD headlamp stickers
There is a service due, so I'm likely to go to the brilliant independent who did the mirrors and the power strut and ask them to have a good old look around the front assembly in case we decide to shoot down to Greece early next year
What I missed was that one of the LED rear sidelights on the passenger side (she is a LHD) has failed so far as I know I'm looking at a new unit...
I've seen a couple on ebay from Lithuania - but really I would like to see what I am buying to make sure that are not faded to death (do they?) and that the replacement wont look !Removed!-eyed
It might be to buy a pair
Anyone have any experience?
Morning Gary
Don't you love just about all car makers what happened to Construction and use regs that state Lamps should be replaceable at the Road Side ??
Now with first Xenon and now LED and Laser lamps they are all sealed units so so all you need to change them is a well equipped garage and a fat wallet 🤣
My E70 has the sealed LED rear units and I have changed 2 with cheap imports both work well and you have to look really closely to tell. Changing Main Beam Dip and Halo/Parking lamps is fun though as it is easier to remove the headlamp from the car !!!
Check www.realoem.com as the Inner lamp (on the tailgate) on the E70 are LED but the main lamp cluster are conventional Halogen lamps
Good Luck
Hello again Dave
......funny you should say that - a few cars ago we had a 2010 A6 Avant need a bulb at the front. I took one look and said not for me. The lad at Halfords was to say unimpressed when asked him to change it. Not something you want to do at the side of the road.
Thanks again for the reminder on the (brilliant) OEM - the part number I find is the official BMW part number 63217217305, which looks to me like three bulbs - the guy where I had the MOT reckoned it was part LED..
