Every warning light on
Every warning light is on the dash. Even the fuel gauge is faulty, ive opened the fuel tank either side under the rear seat and opened up and cleaned the little magnet strip on each one. Still the same. Ive changed the wheels from standard to 18" n forgot about the tire preassure sensors. Could this cause all the lights to fire on the dash n send everythin haywire? Also the discs and pads were changed, could it even be an abs sensor triggering everything?
Hi Patrick
First try disconnecting the Battery Neg first then Pos leave it disconnected for at least 30 mins better yet charge it over night. Reconnect and if the Gods are smiling you should have reset most faults, so any light on the dash will be TPS probably as you have changed the wheels. Either get TPS sensors fitted to the new wheels or code out the TPS system
If your dash still lights up like a Christmas tree you need a diagnostic scan
Thanks man. I will give this a go and let you know the outcome.
Tried it n it still light up like an xmas tree. Had it into an auto electrician months ago n he couldn't get the light ls out. Dunno what am gonna go from here
Morning Patrick
Until you get a diagnostic scan done with a BMW capable system Foxwell, Autologic, iCarsoft or the best BMW ISTA/INPA you are guessing and so are we
So first is there a member on here near to you (cheapest) or find a good Independent Garage or a BMW Specialist (a specialist will have the Diagnostics) There is a Register of BMW Specialists try Google
Good luck
