Morning JC Welcome to the Forum First try the Dealer trick of disconnecting the battery for 30 mins that should clear any faults, if you still get the fault then you need a BMW capable diagnostic system to clear down any fault memory. There are quite a few these days Autel, iCarsoft, and several others Good Luck Dave -
8
module
Morning Frank I think Bimmerparts only trade through Ebay contact them through ebay and you should get a resolution Your car, is the compressor running but not inflating the airbag ? That is the problem worn out compressor they are around £140 and you can get them from Good Auto Factors or sites like Ebay same with Airbags if you need them about £120 should get 2. I would start with the compressor, on start up does it run until it cuts out and you get the suspension warning on the dash/screen but the car isn't rising? Easy to change a real DIY job Disconnect battery, then under the rear of the car remove the plastic under tray and cover box to expose the compressor. Undo the two airlines remove the electrical plugs then undo the 3 mounting screws, compressor out. Reverse the procedure to put it back don't over tighten the air connectors. slowly lower the car reconnect the battery and the compressor will run and inflate the suspension. About 45 mins work plenty of how too's on the Nett As for BMW specialists I think there are 2 or 3 in the Dublin area just Google them then talk to them Dave -
8
Hi all, I have the exact same issue with my 2014 X3. I brought the car to a local mechanic. He replaced all 4 tire sensors due to low battery. He also changed the RDC sensor because the old one was defective. I bought a used one from eBay that the mechanic programmed to match with the tire sensors. The TPM works fine until I parked the car overnight. I bought the car back for the mechanic to fix it but it only work until I parked overnight. It seems like the settings does not save in the memory. I am still unsure if I have a defective used RDC unit. @Waken, could you please tell me what you do to fix the error? Are you able to use the Autel 508 to reprogram the new RDC controller yourself? If so, I would like to get one as well. Thanks in advance for any information you can provide to help! Best, JC -
8
module
As could only happen , courier company saying pkg(module)was delivered yesterday.. except it wasn't.. have checked with neighbours ..no joy.. cant find ph no or email addr for bimmerpartsforless (Millane ind est Brigg!)other thing notice lately is car right down on passenger side rear now...so much so any kind pothole causes serious 'bang' from that corner !!! Trying meantime find someone here (Dublin)who would be able properly identify issue (can't afford main dealer prices) as mechanic who normally looks after car for me is away on holidays (as could only happen ) thinking too again about idea changing it to 'ordinary ' suspension if it comes to it... wondering what sort cost kit do that might be ?? THANKING you again in advance -
Inherited an R56? 2009 ONE
Funny question. Does anyone know if bmw 1.4.0 work on an59 plate mini? it stopped and refused to start. apparently the garage think it’s key has lost comms, but both keys won’t allow the car to start and the battery is dying. im not with the car now but apparently it’s not the starter motor issue and it won’t push start.
