0027ec code 4e89 code
If you can't answer your own question, then I know it wasn't your idea to switch that solenoid with a known good one. You seriously have to be kidding.. so you switched a bad solenoid with a good one and put the bad one where that one came from. And your issue switched up to reflect issues from that same bad solenoid, but now causing errors where the good solenoid came from and no issues where you originally had issues. The whole point of diagnosing a part by swapping it with a known good one is because of the issue follows the bad part... Then the part is no good and you know to replace it. Your mechanic didn't mention this? You had to come ask on a forum? You even kind of answered your own question but to completely answer it, the new code, and the new symptoms you're getting mean that solenoid that you swapped out to test if it was bad, IS BAD. Replace it. Wtf -
Gear selector issues
Hi Shaun Welcome to the Forum I have read several times about this problem though not seen/suffered one myself From what I read the only solution is change the unit two choices, first BMW I have read £1k+ quotes and long wait times for parts. Second choice a used replacement first use www.realoem.com put the last 7 digits of your Vin into the search box it will call up your model get the Part Number for your car, double click the part number and it should show a list of any alternatives if they are available. Then Google to find the part and check prices Apparently it isn't a major issue to swap a DIY job then get your Mech friend to clear and reset codes Good luck Dave- 1
No start.
Hi Steve Cold weather kills batteries get yours checked or charged would be my bet Dave -
No start.
Hi, my x3 f25 normally cranks once and starts it has been cold the last 2 days -3 and ir hasn't been used, went to start today and it just cranks once and will not start,so repeatedly one crank and no start Should it continuously crank till it starts?
