Rattling inside dashboard
Edv
Hi Ed
First empty all the cubby holes and glove box to make sure it isn't a self inflicted rattle
If it's still there when does it start/stop if you push part of the dash does it stop ? Check for anything loose ?
Good Hunting
Hi Dave
the rattling is actually inside the left side of the dashboard, sounds like a bolt bouncing around.yesterday i started
12 minutes ago, Greydog said:
Hi Ed
Good Hunting
e car , 22 degrees and when the idle was reviving up it started, then when idle was achieved it stopped
Thanks Dave , I thought it might be from the housing for the air vent because the sound was definitely from inside the dashboard. Since then no noise .., go figure ?
      Fuel Pump Parts ID please
      Exhaust gasses in an X3
      Bob Palagano
    5. 2
