Need driver's seat module for e24 BMW M6. OE part number 61.1-1 371 916.1
Failed turbo
Got 2017 x1 with 74000 miles driven carefully turbo blown not sure if I've engine damage got quote for 3600 as it dual turbo nd that's no fitted is this worth saving...any advice. -
27
325i push button start switch
Hi. That start/stop ignition button never turns off. Same with the P when parked. I will check the mini fuses on the car. I even added some not in fuse box. I will look for gear and brake fuse. On diagram and #. Thanks -
5
Transfer Case
Morning Darren I brought mine a few years ago (2009 if I recall) through Ebay. Make the checks mine was from a UK seller with good feed back who also offered back up. Before that I used BMW 1.4.0 (still have it on the same laptop) Where ever you buy just make the normal sensible checks to make sure you will have support if needed Dave
