Coding help
Hey everyone, I've just attempted to code in enhanced bluetooth in my f31, (CIC headunit with combox) followed the steps I found https://f30.bimmerpost.com/forums/showthread.php?t=1474066 there, but when I try to go in to the telephone menu all I get is "please wait" and a spinning wheel. Was I too impatient and should have left it off for a while? Or have I made a mistake somewhere? Any advice would be most welcome.
Hi Gavin
All you can do is go over what you did step by step, make sure each step is confirmed if you can, never done the job but it seems straight forward enough.
Maybe do a battery re-set before you start to make sure all is back to a clean start point.
    4. 0
    5. 17
      Massive sudden oil Loss
    • Asultan97 earned a badge
    • JOHN.C earned a badge
    • jonbell earned a badge
    • Mansur Lalji earned a badge
