Servicing f31 ?
X5smw
Hi all, my mate has an f31 and needs the service lights resetting after a service. Could I use my bmw 1.4.0…. Service programme that I use on the e53 series?
if not, what do I need?
cheers
Morning Stu
In a word NO your BMW 1.4.0 works with the I-bus system used by BMW up until around 2006 when they went to D-can then if memory serves around 2010/11 they went to K+D-can. So the lead is different the OBD pinout is different.
With my brother inlaws G31 model we pulled up a you tube video and reset it through the cars system you should be able to do the same.
      Failed turbo
    2. 27
      325i push button start switch
    5. 5
      Transfer Case
    • bill gall earned a badge
    • SGP earned a badge
    • Kandry earned a badge
