BMW Coding Support and Solutions
botsfordpgus47
BMW coding for your BMW 1, 2, 3, 4, 5, 6, 7, X, I, (2004-current E, F, and G, I chassis), and BMW Mini (R5x & F5x) Vehicles using BMW software such as INPA, NCS Expert, and E-Sys. The features below represent a majority of the conveniences that can be disabled/enabled on your BMW (if applicable to your chassis).
Lights
* Amber/Corner lights delete
* Angel eyes as DRL
* Disable bulb out warnings (disables warm and cold testing of bulbs)
* Double flash hazards (not applicable on F-series chassis)
* Pathway lighting with the key fob (follow me home lights)
* Fog and high beams on at the same time
* LCI taillight retrofit coding
* Aftermarket HID coding
* Disable DRL high beams
* Disable DRL taillights
* Front turn signals on when welcome lights activated
* Angel eyes on when welcome lights activated
Cluster
* M style digital speedometer
* True car speed on the digital speedometer
* Lock doors once a certain speed is reached/Unlock doors when the key is ejected
* Turn off the car and eject the key fob by holding the ignition button in when parked
* Nighttime illumination in a cluster with Daytime Running Lights
* Turn signals in HUD
* Disable Auto Start/Stop by default (F and G series only)
* Remember the last setting of Auto Start/Stop (F and G series only)
* Entertainment options in HUD (F series only)
* Recent call list in HUD (F series only)
* Assisted Driving View (G series only)
iDrive
* Traffic options added to CCC/CIC navigation to alert you to any traffic congestion and offer detour options **More info**
* Aux audio input enable
* Enable Mp3 playback (Is your BMW compatible?)
* Bluetooth retrofit coding
* Satellite Radio input enable (needs hardware module to function)
* Cd Changer input enable (needs hardware module to function)
* Remove Legal disclaimer in Idrive
* Remove weather band from entertainment source selection
* Skip AM band on entertainment source selection
* CIC retrofit coding
* CIC DVD-in-Motion (For vehicles with CIC units only) *additional fee*
* Update CCC DVD navigation maps ($15 installation fee). **Do I have CCC or CIC?**
* Climate shortcut display shows in iDrive when fan button pushed (e9x only)
* Seat heater “hi-med-low” slider in iDrive (e6x only)
* Navigation FSC update code for latest Maps *additional fee*
* Radio/Navigation off when the door opened (F series only)
* Automatically set time by GPS in iDrive (NBT iDrive only)
* Enhanced Bluetooth and USB (F series only)
* Side view cameras on at all speeds (F series only)
* Top view cameras on at all speeds (F series only)
* Backup view camera on at all speeds (F series only)
* Remove PDC + Cam disclaimer (F series only)
* Tire pressure + Temperature in TPMS (F series only)
* Phone Ringtone sent to CIC (F series only – not applicable on cars with no navigation)
* DRL front and rear options (G series only)
Climate
* AC blower was not turned on automatically when ignition switched on
* LED fan speed indicator on in the Auto mode
* Pressing “AUTO” on climate control does not turn on AC
Body
* Windows up/down sunroof open/close with a key fob button press
* Mirror fold in with key fob (must-have mirror fold option)
* Disable seat belt butlers
* Disable seat belt chime
* Alarm module retrofit coding
* Change alarm siren type to Euro (E-series chassis only)
* Disable auto-dimming mirror (side-views)
* Disable window safety feature (opening doors will not interrupt roll-up operation – not applicable to E6x)
* Disable door chime when the door is open and the key is in slot
* Enable acoustic notification on lock/unlock (must have alarm module)
* Convertible roof-top open while driving (E-series convertibles)
* Convertible roof-top open with the key fob (E93, and F-series convertibles)
* One-touch auto open/close sunroof
* Easy Entry – seat moves back a little when you open the door (F series only)
* Enable Blind Spot Detection at lower speeds (F series only)
* Reprogram 3rd and 4th buttons on key fob (I3 Only)
* Trunk close with key fob and interior button (F, X3, X5 series only. Not including 6 series F models)
Engine
Diagnostics and Service
* Clear engine and transmission adaptations
* Reset FRM short circuit counters/locks
* Write VIN# and program used replacement ECUs/modules
* Disable Neutral Idle Control per bulletin SI B24 03 08
* New battery registration
* Read/Clear OBD and BMW specific diagnostic codes
* BMW Diagnostics and calibration using ISTA/Rheingold/INPA/Tool32
* Replacement fuel injector parameter coding (N54/N55 engines)
* Adjust idle RPM’s (not available for R5x BMW Mini models)
I3
* Allow 2.4 Gallon Tank Capacity (I3 only)
* Allow REX anytime below 75% “Hold Mode” (I3 only)
* Eco-Pro or Eco-Pro+ on startup (I3 only)
* Traffic Jam Assistant (I3 only)
BMW Performance Power Kit PPK (for N54 & N55 engines)
* For N54 equipped vehicles produced from 03/2008 till 03/2010
* For N55 equipped vehicles produced up till 02/2012
* Increased torque of 317 ft-lbs (manual trans) or 332 ft-lbs (auto trans), available from just 1,500 rpm
* Increased maximum output* of 320 horsepower (see graph image)
* Faster acceleration from 0 to 75 mph
**Please include the last 7 digits of your VIN# in the quote.
Alpina B3 Transmission Flash (for N54 & N55 engines)
* For N54/N55 equipped E9x vehicles produced from 03/2007+
* Smoother shifting
* Quicker up-shifts in D mode (Better fuel economy)
* More precise shifting with fantastic rev-matching on downshifts in Sport mode.
E90/E92/E93 M3 Euro GTS DCT flash
* Improves the jerky or clunky downshifting when coming to a stop
* Quicker and smoother gear shift engagement
* Reduced clutch slip at higher RPMs
* No more lag when shifting into reverse
* Toggling the shifter switches to D2 instead of S3 with S mode memory
N52 Three Stage Intake Manifold Flashing (for N52B30 engines)
* For N52B30 equipped 1, 3, 5, and Z4 series E chassis vehicles
* Up to 255bhp with 221 lb-ft of torque @ 6600rpm (265bhp for the 130i)
* BMW 130i, 330i, 530i, Z4si factory software reliability
**HP gains to wheels will be more conservative.
E46 M3 w/SMG II
* CSL rev-matching and motor inertia DME parameters
* CSL Transmission Software Flash
* Cold-Start Delete
* EWS Delete
* Sport button memory
* Speed governor removal
* Enable shift lights with Manual Transmission
**If the vehicle has aftermarket tune or ECU upgrade please inquire if possible.
