99' Z3 2.8 O/S Rear Trailing Arm Needed
Florian
Damn the tin worm
Have you tried the BMW specialist Dismantlers like Quarry Motors (they have helped me a couple of times) Google BMW Dismantlers there are a number in the UK
Is it the Sub Frame or the trailing arm ? May be off the car a specialist Fabricator could help ? We did this with a friends W210 Mercedes
An after thought have you talked to BMW UK they have a Classic's section
Hi Dave,
Thanks for that still no luck unfortunately.
it is the trailing arm which comes as one part with hub assembly etc.
BMW UK are quoting £1200 for a new part. Have been told a used part should be around £150. So would like to avoid if possible!
surprised that there isn’t anything aftermarket available!
Florian
4 hours ago, Florian said:
Yes! Seems like RHD and LHD parts are interchangeable however.
Florian
I have a pair that I was hoping to get powder coated that I may split.
when do you need them by?
Was really only after the right side but if you need them gone as a pair I’d be happy to take both.
After them as soon as possible really the poor thing has been off the road for a month!
Florian
      Centre console iPhone charger
    3. 4
      Failed turbo
      Failed turbo
    • Massivemark earned a badge
    • Ste B earned a badge
    • mike1957 earned a badge
