Wheel size
Mel w
Morning Melvin
Short answer yes you can, I believe 20" were also available
You can check at www.realoem.com it is a BMW Parts List just put the last 7 digits of your Vin into the search box and it will call up your model then look in the wheels/tyres section for correct fitment
Hi Melvin
The different size wheel / tyre combinations are calculated to be as close as possible in diameter so as not to effect the speedo reading
Example a 225x50x17" tyre/wheel will have a diameter of around 657mm a 225x40x19" wheel/tyre will be around 662mm and a 225x35x20" tyre/wheel will be around 665mm The difference being just a few mm will not effect speedo readings
If you were to go for say 20" wheels and tyres to fill the arches better in a staggered set (wider rear rims) front would be 225x35x20" and 665 mm/dia rear would be 255x30x20" and 661 mm/dia
If the wheels and tyres you are considering are After market items check realoem to ensure that the bolt pattern and offsets are correct
      Failed turbo
    2. 27
      325i push button start switch
    5. 5
      Transfer Case
    • bill gall earned a badge
    • SGP earned a badge
    • Kandry earned a badge
