Slight vibration
Slight vibration at about 70ish mph through the car , not steering seems to improve at higher speed. But under heavy breaking you also fill a vibration
Ment to say 2012 520 f10
Morning Christopher
Obvious things I would check,
Tyres balance condition and wear any splits or lumps in the side walls tread wear even side to side front to rear all inflated correctly.
Suspension and Driveshafts, nothing loose or allowing movement wheel bearings OK
Brakes, Any binding or sticking pads or calipers. After driving any heat felt at the wheel centre would indicate an issue
Propshaft, Centre bearings can wear
Other things that can cause vibration are Engine pulleys belts and tensioners
Hope this helps
