Accoustic cover location
Paul26May
I have just had my engine bay cleaned in order to locate an oil leak. Turned out it was something to do with the plastic parts attached to the turbo however I have 2 pieces left over that the garage forgot/neglected to put back and I haven't the foggiest as to where they go? Any ideas anyone? Help would be much appreciated.
Morning Paul
Take a look at www.realoem.com it is an online BMW Parts List put the last 7 digits of your Vin into the search box it will pull up your model, then look in the engine section. Once you find it get the part number in case you need to buy new.
Just had a quick look seems to be part 3 for one of them don't see the other unless it is part of another acoustic panel
ENGINE ACOUSTICS
Hope this helps
      Centre console iPhone charger
    • Penguin82 earned a badge
    • Stuiggy earned a badge
    • Massivemark earned a badge
    • Ste B earned a badge
