Side Panel Lights - Moisture ingress and Bulb Specification
Transfer Case
Where would be the best place to purchase Ista /Inpa Regards Darren -
Hi all, time for me to change my front discs on the E64. Has anyone got any experience on discs manufacturer and things to avoid. I am just going for plain vented discs as per standard spec on the vehicle. Advice always welcome -
Transfer Case
Morning Darren The obvious one is BMW ISTA/INPA not the cheapest but by far the most comprehensive and gives Dealer level access. Require a little patience to master but well worth it (my opinion) Then there are systems by Autologic, iCarsoft, Bimmerlink and Foxwell, all work well but are not as comprehensive as ISTA/INPA (mine has WIS and TIS). There are also a few systems which are Subscription led such as Carly Personally if I have tools I want to own them not rent them so I prefer to buy the complete package (on an old laptop that lives in my garage I have Diagnostics programs for Volvo, Merc, VW, and BMW. Plus an Autologic scanner and a BMW iCarsoft scanner (I am a born tinkerer and a boy needs toys) One diagnostic session at a Dealer will probably cost close to £200 plus any remedial work they can recommend?? So owning your own which will allow adaptions, registration and reprogramming work to be carried out will save £££ in the long run. Good Luck Dave -
10
2024 X5 with Towing package using weight distribution hitch
Just realized that I made a mistake. The last sentence should have been: " You would plug the trailer’s 7-pin into it, then the 7-pin coming out of the controller to X5." -
10
Besides, I could never understand why someone would sell you something but not set it up for you to use. BMW USA is not the most logical company to talk to, just like they would advise against using WDH but could not produce documentation to support it. Fortunately my dealer was helpful when I tried to figure out the break controller wiring. They even ordered a set of plugs for me although I eventually went with the Etrailer harness.
