Engine cuts out
Matto72
Hi guys, I after some help I have a 2012 528i and today it’s started cutting out when I try to accelerate away hard . It’s fine under anything under half throttle, but over this the engine and all electrics cut out
A Diagnostic Scan  would help as it could be any number of things. When was its last service? When was the fuel filter changed last? Can you get the pressure checked at the fuel rail? Check the plugs and coil packs.
Sorry to raise more questions than answers but a scan would tell you more
      Failed turbo
    2. 27
      325i push button start switch
    5. 5
      Transfer Case
    • bill gall earned a badge
    • SGP earned a badge
    • Kandry earned a badge
