Trailer check message on display
Swingy_p
Hi all,
Have just been out and am now getting this message come up everytime I use the indicators,
Trailer Indicator Left
Trailer Indicator Right
can't find much info on where to look for a solution so anyone out there that's able to point me in the right direction
Thanks in advance
Paul
Morning Paul
First do you have a tow bar fitted ? If you do then first check the connections at the trailer plug, check the PDC controller (there is a connector black I think that lets the control system know the trailer is connected) The last is a check on the LCM for faults so a code read will be required, while reading the fault codes you could turn off the trailer light check.
2 hours ago, Greydog said:
Morning Paul
Morning Dave,
Thanks for the info 👍🏻
Checked the trailer electrics plug under the bumper and loads of water came out so I guess that's gonna be my issue 🙄
Cleaned and dried the plug and covered the cover and connections with a good helping of silicone grease so hopefully that has solved my issue.
Thanks for your continued help in getting to know this beast of a car
Paul
    4. 0
    5. 17
      Massive sudden oil Loss
    • Asultan97 earned a badge
    • JOHN.C earned a badge
    • jonbell earned a badge
    • Mansur Lalji earned a badge
