Auto gearbox "braking"
Just meant ordinary speed reduction when slowing down. Have just come from an EV which had regenerative braking which I accept is a totally different thing. Thanks for putting my mind to rest -
Massive Oil loss under engine
Morning Paul Wow that's a bit of a mess, the fact it went so quickly my thoughts are Oil Cooler pipe split, Remote Oil Filter feed/return pipe off or loose, Sump plug lost ? Good luck hope it is a relatively simple fix and that there is no other damage Dave -
Morning Richard The Gearbox has very little braking effect in normal driving there are hill descent settings which give some braking and even change down a gear but from memory (dangerous) that only kicks in at speeds below 30mph Or are you talking about the emergency braking system fitted to some models with cameras? Dave -
