Discount: Ultimate Styling
Failed turbo
Got 2017 x1 with 74000 miles driven carefully turbo blown not sure if I've engine damage got quote for 3600 as it dual turbo nd that's no fitted is this worth saving...any advice. -
27
325i push button start switch
Hi. That start/stop ignition button never turns off. Same with the P when parked. I will check the mini fuses on the car. I even added some not in fuse box. I will look for gear and brake fuse. On diagram and #. Thanks -
Looking to buy a used 2015 650i w/ low kms, any advice?
Hello fellow BMW enthusiast, I'm looking to purchase a 2015 650i xdrive with 70K kms. I understand I'll need to hold some cash back for maintenance/repairs and have another car if it needs to be in the shop. I don't have a garage so I won't be servicing it myself. Anything I should be looking for before I buy and is this even a good idea? Any advice would be greatly appreciated! Geoff -
New Front Brake Discs Recommendations
Hi Paul Last set for the X5 were from Euro Car Parts by QH Disc's and Pads around £100 if my wallet remembers correctly Dave -
5
Transfer Case
Morning Darren I brought mine a few years ago (2009 if I recall) through Ebay. Make the checks mine was from a UK seller with good feed back who also offered back up. Before that I used BMW 1.4.0 (still have it on the same laptop) Where ever you buy just make the normal sensible checks to make sure you will have support if needed Dave
