eml and check engine lights on car in limp mode any suggestions?
5
Transfer Case
Morning Darren I brought mine a few years ago (2009 if I recall) through Ebay. Make the checks mine was from a UK seller with good feed back who also offered back up. Before that I used BMW 1.4.0 (still have it on the same laptop) Where ever you buy just make the normal sensible checks to make sure you will have support if needed Dave -
5
Transfer Case
Where would be the best place to purchase Ista /Inpa Regards Darren -
Hi all, time for me to change my front discs on the E64. Has anyone got any experience on discs manufacturer and things to avoid. I am just going for plain vented discs as per standard spec on the vehicle. Advice always welcome -
5
Transfer Case
Morning Darren The obvious one is BMW ISTA/INPA not the cheapest but by far the most comprehensive and gives Dealer level access. Require a little patience to master but well worth it (my opinion) Then there are systems by Autologic, iCarsoft, Bimmerlink and Foxwell, all work well but are not as comprehensive as ISTA/INPA (mine has WIS and TIS). There are also a few systems which are Subscription led such as Carly Personally if I have tools I want to own them not rent them so I prefer to buy the complete package (on an old laptop that lives in my garage I have Diagnostics programs for Volvo, Merc, VW, and BMW. Plus an Autologic scanner and a BMW iCarsoft scanner (I am a born tinkerer and a boy needs toys) One diagnostic session at a Dealer will probably cost close to £200 plus any remedial work they can recommend?? So owning your own which will allow adaptions, registration and reprogramming work to be carried out will save £££ in the long run. Good Luck Dave
