Help! My radio and voice command aren’t working
Mauri
Quote
I took my 2009 BMW 650i convertible in to have some front lightbulbs replaced.  When I picked it up no radio or voice command system.  The repair shop denies any responsibility.  I think it is a quick fix but I don’t know what I am dealing with.  Anyone else have a similar problem?  Thank you.
Morning Mauri
Did they disconnect the battery ? Can't think why but possible?
Have you checked the obvious fuses etc I have seen a fuse not blown that needed removing and putting back before working? Your Radio also has a 10a fuse under the Quadlock connector on the radio unit in the boot.
Hope this is some help
      Transfer Case
    3. 4
      Transfer Case
    4. 10
      2024 X5 with Towing package using weight distribution hitch
    5. 10
    • Bertiefor earned a badge
    • lucas earned a badge
    • B10Neil earned a badge
