Ac condensate drain.
Kildare dave
Hi Dave
If I recall the condensate should drain a the back of the gearbox under the car I did read about issues with a hidden drain under the Ebox that can only be checked from the passenger wheel arch behind the liner
Try looking at www.realoem.com it is an Online BMW parts list put the last 7 digits of your Vin into the search box it will bring up your model then search the sections for what you want. There are small exploded drawings that may help.
      Failed turbo
    2. 27
      325i push button start switch
    5. 5
      Transfer Case
    • bill gall earned a badge
    • SGP earned a badge
    • Kandry earned a badge
