44cc fault code
help!!! 2007 320d,car has no boost,fault code 44cc comes up,have put a new actuator on it and turbo unit sent away and set up,replaced maf,map,boost pressure solenoid,air intake temp sensor and still no boost! can anyone please help!!!
Hi Stuart
Seems like you have covered all the usual culprits. After fitting were all faults cleared down? Have the pins in the ECU been checked for continuity? Just in case its a corroded pin at the ECU
4 hours ago, Greydog said:
Hi Stuart
yes all faults were removed but this one keeps pinging straight back up,I have looked at the pins and there didn't seem to be any corrosion there,ill get a multimeter onto them though and check that,thanks for the info!
      Centre console iPhone charger
    • Penguin82 earned a badge
    • Stuiggy earned a badge
    • Massivemark earned a badge
    • Ste B earned a badge
