E91 rear door lock
Ridler89
Hi Ridler
First the obvious have you checked the wiring to make sure there are no breaks in it? If all OK then the probable cause is the actuator not to difficult to change take a look at www.realoem.com put the last 7 digits of your Vin into the search box it will bring up your model, then search the relevant section so you have the Part Number then Ebay and Google search for a replacement at a sensible price.
    2. 5
      Transfer Case
    3. 5
      Transfer Case
    5. 5
      Transfer Case
    • Julian4285 earned a badge
    • Bertiefor earned a badge
    • lucas earned a badge
    • B10Neil earned a badge
