front wishbone change
gary-the-sparks
Hi Gary
I helped a neighbour change both front wishbones on his wife's car near side was bent he thought due to "pot holes"
Take a look at www.realoem.com it is a BMW online parts list. Put the last 7 digits of your Vin number in the search box it will bring up your model the look at the Front axel section. You will be able to get the correct part numbers to get the correct replacement whether from BMW or from a Motor Factor or Auction Site.
My neighbour changed both as he brought from a Motor Factor and wanted both to match.
      Bob Palagano
    2. 8
    5. 2
    • Congers earned a badge
    • bobpalagano earned a badge
    • Asultan97 earned a badge
    • JOHN.C earned a badge
    • jonbell earned a badge
