7 series sky lounge shade will not retract
K24DAS
13 hours ago, Greydog said:
Morning Das
As your car is 2019 it should be covered by BMW's Warranty so your local Dealer should be a starting point
Hi Dave,
Thank you for your input. I thought there may be something I can do to reset instead of taking it to BMW. I will give them a call.
Thank you.
Regards
In case anyone else has this problem, here here a way to fix the problem.
After reading the user manual thoroughly. I used the sun roof initialization method.
As per instruction the outside temperature has to be above 5⁰c. Press and hold the open vent button for your roof until it initialises. This will close the vent, open the roof and the rear shade, close everything again (front and back). Initialisation is now complete and everything should be in working order.
      Centre console iPhone charger
    2. 4
      Failed turbo
    3. 4
      Failed turbo
      Failed turbo
    • Ste B earned a badge
    • mike1957 earned a badge
    • bill gall earned a badge
    • JCR earned a badge
