Just wanted to say hi. And of course after bit of advice
325i push button start switch
Hi. That start/stop ignition button never turns off. Same with the P when parked. I will check the mini fuses on the car. I even added some not in fuse box. I will look for gear and brake fuse. On diagram and #. Thanks -
5
Transfer Case
Morning Darren I brought mine a few years ago (2009 if I recall) through Ebay. Make the checks mine was from a UK seller with good feed back who also offered back up. Before that I used BMW 1.4.0 (still have it on the same laptop) Where ever you buy just make the normal sensible checks to make sure you will have support if needed Dave -
5
Transfer Case
Where would be the best place to purchase Ista /Inpa Regards Darren
