How to replace rear parking sensors BMW X5 E70
wilko01
Afternoon Ian
First look at www.realoem.com put the last 7 digits of your Vin into the search box and it will call up your Model. Then look at the PDC section and note the part numbers so you know your getting the right replacements.
The sensors you can reach from below the bumper at the rear (front is more of a faf) Remove the plug twist and pull.
Morning Ian
Mine is an E53 not E70 so slightly different but  I know the E53 have an inner and outer housing which clip into place the sensor is push and twist then the plug. The E70 looks as though its flush to the bumper so I assume there is just an internal bracket that holds the sensor it will be a bayonet type push and twist
Have you checked www.realoem.com there are exploded drawings that should help
Have you checked You Tube for help?
    5. 0
    • Asultan97 earned a badge
    • JOHN.C earned a badge
    • jonbell earned a badge
    • Mansur Lalji earned a badge
