Failed MOT
Sheri
Hi Sheri
Are you aware of the Government website where you can check the MOT and its MOT history https://www.check-mot.service.gov.uk/ just put the Reg number in the search box you can also check any outstanding recalls on the same site.
2 front shock absorbers and drop links for the anti roll bar  should have been fitted to get through the MOT (check the site above for any new advisories) I assume the other defects are fixed. The one to check is the oil leak take someone with some knowledge with you to check.
If you still want the car use any of these things to negotiate the price down by the cost of repair after all you dont want to buy something that will cost you money straight away. Lots of X3 about so don't be afraid to walk away.
Hope this helps
    2. 5
      Transfer Case
    3. 5
      Transfer Case
    5. 5
      Transfer Case
    • ren earned a badge
    • Julian4285 earned a badge
    • Bertiefor earned a badge
    • lucas earned a badge
