air suspeneion self levelling inactive
Morning Mark
How frustrating is that
First check the fuses in the right hand cubby in the boot 2 to check 7.5amp and 30amp if either are blown. If the fuses are OK the compressor should run, however if a clumsy fitter has clouted one of the ride height sensors when removing/replacing a wheel so check both are OK and the knee joint needs to be pointing at the wheel not inwards.
Last is your battery OK low battery voltages on a tired or failing battery will trigger the fault.
If you aren't aware take a look at www.realoem.com there are some small exploded drawings that may help, also www.newtis.info
    5. 0
    • Asultan97 earned a badge
    • JOHN.C earned a badge
    • jonbell earned a badge
    • Mansur Lalji earned a badge
