Side markers and axle noise
Neo
Hi there
Im looking for a used white bumper markers and a question regarding a diff noise. I bought a z3 with a modification to 2.0 eng insdead of the original M44.
Axle has winding unloaded and I must find what is the ratio for 2.0 auto in order to buy one.
Plus I need 2 side markers used but white.
Cheers
Neo
Edited by Neo
Explaining my needs
Hi Neo
Welcome to the forum
Use www.realoem.com go to the classic section then search for the parts you need, this will give you the BMW part numbers you need then google is your friend search for a supplier new or used.
Hi again
Thanks for the tip
Is the site possible to clear out rjw ratio for the 2.0 auto ? Because i bought it without checking what the Chassis code  .Now I understand the CH72 means.m44 engine😟 I was looking for a 2.0 auto and I was traped!
Anyhow I have to change the diff to fit to 2.0 ratio.🍺
      Centre console iPhone charger
    • Penguin82 earned a badge
    • Stuiggy earned a badge
    • Massivemark earned a badge
    • Ste B earned a badge
